Finally got it. New user error of missing the “insert” button.If it won’t upload, put it on YouTube and add the link here.
Thanks! Sounds like an easy enough test. PO had mentioned an A/C issue but of course it wasn’t making this noise when purchased so I figured the two were possibly related.Sounds like one of the accessory belt pulleys or bearings. Let it squeal at idle and spray some WD40 on each individual pulley until the noise goes away. Then you’ll know you’ve found your culprit.
I thought that was in the Georgia mountains near a stream with a banjo playing in the background.Squealing noise when starting that goes away after I drive a few miles.
That happened to me once in northern Arkansas while driving by a pig farm.
Yes this but...Sounds like one of the accessory belt pulleys or bearings. Let it squeal at idle and spray some WD40 on each individual pulley until the noise goes away. Then you’ll know you’ve found your culprit.
