I was nearing the end of a 9 hour drive when I noticed a squealing sound, it almost sounds like a bearing going out, however, it isn't one of the pulleys, not the belt, and sounds further back near the transmission. I have the 4.0 with a manual 5 speed, with 130k miles and about 3000 miles on a new clutch. the sound speeds with rpms, doesn't start until about 18k rpm, and usually goes away at idle. pushing down on the clutch does not make a difference in the sound. I changed the transmission fluid and that didn't fix the sound. also, it makes the sound while stopped as well. any ideas? thanks! - Tyler
