I bought my stock 04 Rubicon last Dec w/ 185k miles. It's been running fine around town but I've taken it out to a lease with some fairly steep (in my limited experience) off road hills and stalled it. I'm probably still learning to drive manual transmission, particularly in more challenging situations and didn't downshift enough so it bogged down and died a few times. The check engine light came on and is consistently reading just P0351 (Ignition Coil "A" Primary/Secondary Circuit). The first time I didn't have my scan tool with me and the light eventually went out on it's own a little bit later and read/cleared code when I got home. This weekend it happened a couple more times and captured freeze frames (below). First time I was in 2nd gear (2H) and it seemed better after restarting and clearing code. The last time I drove around slowly in 4L and I felt like I was losing power going up normal hill back to camp in 2nd (still 4L) and the CEL came on during climb but it kept running. It was kind of running rough at that point stuttering, maybe misfires. It seemed to get back to normal after restarting it.
According to my records the previous owner replaced valve cover gasket and spark plugs earlier in the year, Feb '19 at 175k. There was a prior note about exhaust system leaks and RMS leak in 2015 at 118k and no other documentation of fix. I took it to a shop for pre-buy checkout and they noted valve cover gasket may have been leaking, but it was also really dirty at the time or leftover from prior fix. I mentioned it was recently done and they said it was a crappy job, but just looks like a blue fel pro to me and I can't really tell. There is still an oil leak, which appears to be rear main seal to me, but haven't really looked too hard myself. They also noted replacing vacuum hoses (not sure which) and clean throttle body which I haven't done yet, but did replace most all fluids, belt, hoses, brakes.
Anyways, my concern with the code this last time is that it wasn't my fault driving. Unlike other descriptions I'm not seeing misfire codes being reported (maybe the first time, but don't recall and not the past couple I've saved),. Is it very common for just one coil to go bad? Should I see corresponding misfires logged? If it was the control signal, wouldn't I see a pair of cylinders fail together? A vacuum leak would likely effect all cylinders and not consistently the one? I've also never seen this around town (~14MPG), so it seems weird that it's only under this kind of load and I'm more curious about bigger problems like compression or exhaust leak. I'm debating taking it to a shop to look at before I tear into it, but they likely won't be able to reproduce the situation either. I could probably just replace coil pack myself cheaper than having them even look at it, but not sure if that's a good bet in this scenario.
From searching this seems to be good description:
https://repairpal.com/obd-ii-code-p0351
Mode $02 - Freeze Frame
PID | Description | Value | Units |
0x02 | Freeze frame DTC | P0351 | |
0x03 | Fuel system 1 status | 2 | |
0x03 | Fuel system 2 status | 2 | |
0x04 | Calculated load value | 10.59 | % |
0x05 | Engine coolant temperature | 195.8 | F |
0x06 | Short term fuel % trim - Bank 1 | -4.69 | % |
0x07 | Long term fuel % trim - Bank 1 | 5.47 | % |
0x08 | Short term fuel % trim - Bank 2 | 4.69 | % |
0x09 | Long term fuel % trim - Bank 2 | 4.69 | % |
0x0B | Intake manifold absolute pressure | 25.4 | inHg |
0x0C | Engine RPM | 640 | RPM |
0x0D | Vehicle speed | 6.21 | MPH |
0x04 | Calculated load value | 16.08 | % |
0x05 | Engine coolant temperature | 192.2 | F |
0x06 | Short term fuel % trim - Bank 1 | 11.72 | % |
0x07 | Long term fuel % trim - Bank 1 | 3.12 | % |
0x08 | Short term fuel % trim - Bank 2 | 13.28 | % |
0x09 | Long term fuel % trim - Bank 2 | 2.34 | % |
0x0B | Intake manifold absolute pressure | 12.7 | inHg |
0x0C | Engine RPM | 1984 | RPM |
0x0D | Vehicle speed | 4.97 | MPH |
