Having issues 1997 Jeep Wrangler4.0 with Automatic.
Stopped on the way home this evening and after leaving Auto zone, jeep would not start up. Dash lights up like normal, but when turning the keep all the way starter does not energize...not even a solenoid clicking sound.
I jumped the small lug on solenoid directly to + Battery Terminal with keep turned and it fired right up.
Immediately thought the Ignition activator pin was broken so bought a new one and after jumping the solenoid again drove to replace it.
Got home and pulled ignition all apart but when I pulled the old ignition activator pin out I noticed that it was the same length as new one so not broken....
Returned the new switch activator......
Then re attached the switch (Plastic housing with electrical contacts) itself back into place since I noticed the T10 ground screw, and with a screw driver turned the switch and the starter would not engage.
Really seemed like it was drawing down the power......
Went and bought a new switch and installed and the jeep started right up again.....
short time later I tried starting it again and once again....nothing.
After several more attempts started up but then noticed my back up lights on steady while in Park?
Checked the #2 40 Amp Fuse visually and checked with a meter and no issues.
Replaced the starter Relay with a new relay and still nothing.....
Jumped across starter relay 30 and 87 and starter engaged as normal and engine fired up.
Seems like I may have a wiring issue but does any one know where to start checking?
I did notice the tie wrap that hold the wiring harness near the right side of the bell housing was broken and harness was laying against hot exhaust pipe but went through the wires and did not see any melted insulation or exposed wires and tired it back up away from the exhaust.
Measured the battery at 13.7 Volts......
does any one have any ideas on where to trouble shoot next?
