I have a stock 2000 tj with factory aluminum wheels which are like new. Is there a chart which shows 15" steel wheels from other manufacturers that will fit. I want to use them in the winter with other tires and not ruin the stock aluminum ones.
Stock TJ wheels have 5.5" of backspacing.
there ya go, i knew someone would fix it i was not sure and have since looked and found 5.25-5.5" BS for stock TJ wheels.
Fixed that for accuracy.Any aftermarket ones will all "fit" as long as the bolt pattern is correct. They might stick out farther and look better and cause your steering and handling to improve.
Any aftermarket ones will all "fit" as long as the bolt pattern is correct (and hub bore is big enough). They might stick out too far and wear out your ball joints and bearings quicker.
Offset is a more useful measurement for car wheels, backspacing is a more useful measurement for Jeep and truck wheels. That's why we're always discussing backspacing in Jeep forums and not offset.I still believe offset is a better measure and that's what is cast into the back of the wheels too.
