Long post ahead. But I am super thorough in an effort to get the answer I am looking for.
I'm installing a 3 1/2" Super-flex kit on our 2001 TJ and I have completed (almost) the entire front end. I still need to bleed the brakes and align it. Which leads me to my question(s)...
After centering the axle under the jeep, my measurements have it sitting within 1/16" side to side. I'm going to take that as good unless someone suggests otherwise.
I did not disconnect any steering components other than the track bar during the install. Once the Jeep was sitting on it's own, (on jack stands under the axle) the steering was quite far off. Less than a quarter turn (roughly 45 degrees).
I centered the steering wheel in the cab and then proceeded to adjust the drag link to get the wheels as close to straight as I believe them to be. Now to simply adjust the toe-in, correct? Yeah....not so much.
I replaced all the steering components about 4 months ago and the Jeep tracked nice and straight afterwards. During that install, I never did confirm that the axle was in fact, centered. There was a 2" budget boost from the PO recently installed(no control arms, no new track bar, just springs and shocks) After trying to dial in the toe I feel like I'm going to have to disconnect the driver side tie rod end from the spindle to get the passenger side straight in alignment with the passenger rear tires, adjust the tie rod to set the driver side straight with the driver rear tire, and then, adjust the toe-in to 1/8" . So after all that, my question is, is it feasible that the new height has thrown out all my steering adjustments and I basically need to start from the pitman arm and work all the way down to the tie rods to get it perfect?
In my mind, I just expected to need to adjust the drag link to get back to straight but it's proving to need a full reset. All I can think of is the new track bar length and recentering of the axle has compounded things.
Thoughts?
Thoughts?
