All,
I have a 2006 TJ. I replaced replaced the Tie Rod and Drag Link (Crown Automotive HD Steering Kit Steering) Drive side tie rod feels loose. In order to get a tight fit the castle nut is below the cotter pin hole. I am assuming the hole is wallowed out and the knuckle needs to be replaced? Should I replace the passenger side also? TIA
