Recently I decided to replace all seals in my 2000 4.0 steering box due to a long term leak. It was the original. I decided to do it myself mostly for the experience. It was way easier than I thought - followed
. Made it super simple.
I marked the adjusting nut and box with a punch like he describes (the one that determines the preload for the spool valve). When I put it back together I tightened it back to align the punch marks, but inadvertently tightened it one complete turn less. I’d always had a couple inches of slop in the wheel and had always assumed it was just normal for a TJ. But after I reinstalled the steering box, I now had about 30-40 degrees of slop. I figured out what I did wrong pretty quick and pulled the steering gearbox back off and tightened that adjusting nut one more turn, but rather than tighten it around to the marked punch marks I decided to tighten it the way the service manual says (all the way tight, then back off 5 mm). To my surprise the correct location was about 75 degrees past where I had marked (past where it was originally). I reinstalled it, and it now steers better than it ever has. Absolutely zero slop at the top. It is wonderful. The wheel response is great - feels like a new vehicle. I read a lot about adjusting the pitman shaft adjustment screw, but I bet a lot of people just have an incorrectly tightened spool valve preload adjusting nut. According to the service manual the spool valve preload should be adjusted prior to adjusting the pitman shaft adjusting screw. Anyway, FWIW thought I’d throw it out there because it worked awesome for me. Realistically, if I wasn’t replacing the seals it would take me about 30 min to pull the box, check the preload, and reinstall.
