I recently purchased a 1999 TJ and I'm trying to fix a sway issue. It appears the problem is the rear lower control arm bushings. A local tire shop checked it out and said the steering stabilizer was bad as it had a dead spot in it. Is that normal?
Yeah, but what is the tire pressure?I will check the anti sway bars. It has 31x10.5x15 tires and Les Schwab just checked the alignment and tire pressure
X2 and what did Les Schwab say the toe-in and caster angles were? Do you still have the printout?Yeah, but what is the tire pressure?
42psi??? What in the world were they thinking. Drop them like JMT mentioned and take it for a spin.I just checked the tire pressure and it's 42psi
