Okay, Is my plan of lowering down the psi and hopefully getting the tires to wear more evenly a good one? I just bought them and they have a ton of tread left so I’d rather not trash them, also, my wheels are lug centric and not hub centric. Could this be attributing to the problem and would hub centric rings help?If the wobble started when you changed the tires it seems like that is mostly likely the cause. Even though the tire isn’t out of round (aka flat spots, bent rims, etc) you can still have something going on with them like a sidewalk deformation, that won’t shop up on a lot of tire balances. You usually see stuff like that on low profile tires however, not beefy off-road ones.
