It's me ... again. I have a '97 TJ and was experiencing some difficulty shifting (and random grinding going into 2nd & 3rd gear) that came on rather suddenly. One week just fine, next week not so much.
In possibly a rushed decision, with it having 230K miles and being 27 years old (and original) I decided to just go ahead and replace the clutch (LUK Kit) w/ National brand TO Bearing (all metal) and a new pilot bearing along with a clutch fork and pivot ball.
I maybe shouldn't have gone to the more difficult path first but here I am, plus I figured she was due.
I did this over the winter and only just got her back on the road about 3 weeks ago.
I have a few questions so I can make sure the problem doesn't make itself more expensive.
My problem/question is, it still does not want to shift smoothly and in some cases not go into gear at all. It also got stuck in 3rd gear (temporarily).
I am the original owner and she has 230K miles.
- Is there a way to know if I greased the pilot bearing enough?
- Could the slave cylinder assembly be causing my issue? (I do not see signs of leakage & fluid level is where it is supposed to be/unchanged level)
- Any way to tell if it is my synchronizers (before pulling the transmission)?
- Anything I could be missing/other suggestions??? All would be welcomed!
