2000 Wrangler 4.0 Sport.
I had the hyperflashing happen on my right side of the Jeep and found a burned out bulb and a corroded connector in the front turn signal.
Cleaned the connector and put everything back together and all turn signals are working fine now.
My issue is that now the left front turn signal and clearance lamp come on when I press the brake pedal. Honestly it may have been doing it before but I didn't notice it due to focusing on the hyperflashing.
I went through all the plugs and connectors on both sides, removed the taillights and cleaned their grounds with no change.
Everything appears to be working normally except for the lights coming on with the brake lights.
I'm not sure where to go next as I've already cleaned the connectors and grounds.
Anyone ever experienced this? Thanks.
