So this is an odd one, and it just sounds weird but it's loud and obnoxious. Just some quick background, I have a 2000 Jeep TJ sport that I had a Dana 35 put in a year or two ago that came from a newer Rubicon, limited slip with an e locker. Everything was good. Last year I replaced the drum e brakes cause they were gone, and while at it I replaced the pads as well. At some point after that I started hearing this sound at varying levels of intensity. I took the wheel off, inspected the brakes, made sure nothing was rubbing. Put everything back together and it was gone...for like a day. Later on I pulled it off again, removed the rotor and inspected everything again. It was possible that some of the tabs sticking off the drum brakes were maybe rubbing or something so I just ground those down a tiny bit. Again day or two without the noise and it slowly came back.
When I'm driving it starts as soon as I start pushing on the brakes. If I push on them very hard and stop aggressively it goes away almost completely, but as soon as I lighten up to come to a smooth stop it comes back in. I have to hit the brakes pretty hard to slow down without the noise. At slow speeds I've pulled the e brake just a little until I feel some slight resistance and it still occurs, no change. Is it possibly something with the drive shaft? Any ideas? Appreciate any assistance!
