Suspension Bolt Torque Spec
Thumper4fun
Gadsden, AL
Just picked up a new to me 2000 TJ Sport, Auto, 69K miles, locally owned rig. It has a 4" RC lift that appears to have been installed fairly recently, Nitto Grabber 285/70/17s mounted on KMC XD808 17x9 wheels. Jeep is in great shape inside and out but rides like a wagon, seems to drift around the road and will shimmy after hitting a dip or pot hole. I checked the tire pressure and set it at 26 psi on all 4 corners. That helped some. Then I crawled under the jeep to check the front suspension. I found the track bar was loose. So I figured I better go through all the suspension bolts and torque them to spec but I don't have the torque specs. Anyone know where I could find those and would the factory torque specs be any different than the lifted components torque specs?
Thanks Mots, that will help. Those service manuals would be a big help if someone could direct me to them. Also, does anyone know if I torque the bolts while the jeep is on the ground or should the suspension be unload and on jack stands?
