SYE Upgrade Speedo Sensor
davidgoodman
Henryville, IN
I am doing a T-case overhaul and Advance Adapter SYE. Does the speedometer drive install in the same orientation as it was on the original tail shaft casing? I am guessing the mounting point on the AA SYE tailshaft housing is offset to compensate for the different diameter speedo drive gear on the new shaft but would like to confirm.
I tries to wiggle a borescope in there but can’t get it in view.
Thanks in advance.
I’m new on this forum and the question asked here from 2019 is the reason I’m here. I bought a used transfer case with SYE and the blue speedo drive gear spins on the shaft due to the plastic splines being worn. So where do find a new blue drive gear and what driven gears do I need for correct speedo operation. I’ve rebuild both differentials and changing from stock gearing to 4.56. Thanks in advance!
https://wranglertjforum.com/threads/which-speedo-gear-do-i-need.15362/post-247383
There's options on Extreme Terrain , Quadratec, and many other sites. Figure out which gear you need and then just Google something like "jeep tj speedo gear XX tooth" and take your pick.
Or a whole set
https://share.google/koYYD5FfbgpGmEdPw
Reactions: macleanflood
mine installed the same way as the old tailhousing. I imagine the new housing is cast correctly to account for the different gear. There are notches to use based on which gear you have on the sensor.
