Hey guys... can I use canola oil in my 4.0? I've heard it will unlock extra horsepower.
And I thought you west coast guys were more earth-friendly and would use Cali/Oregon grape seed oil.
Excerpts from your link:
"[Synthetic oils] are also more expensive and might be overkill for the average person driving to and from work, getting groceries and taking the kids to soccer practice and school."
". . . [A] synthetic oil can run longer oil drain intervals, in more harsh conditions than their mineral oil counterparts. . . . For some people this is an important factor, for others it might be overkill. Whatever you choose – make sure you follow your owner’s manual recommendation and match the type of oil you buy to the oil drain interval you follow." [Emphasis supplied.]
"You do not have to use synthetic oil, but there can be some real advantages to doing so. There are lots of people who use synthetic, just like there are a lot of people who do not."
The first and third excerpts acknowledge that synthetic motor oil isn't appropriate for everyone and every situation. The second demonstrates why synthetic motor oil isn't necessarily the best choice for a jeep engine.
The drain interval recommended by the Chrysler for Schedule B "severe duty" use is 3,000 miles. For light duty use the recommended service interval is 6,000 miles. If one follows BOBistheOilGuy's advice and matches the type of oil to the factory recommended service interval, the best match will not be full synthetic motor oil for most jeepers in most climates. Instead, the best type match will often be conventional motor oil for Schedule B and either conventional or a synthetic blend for Schedule A.
There are many valid reasons for choosing synthetic motor oil. A blanket statement that synthetics are "superior in every way" isn't one of them. Apparently neither is a non-specific citation to BOBistheOilGuy. However, BOBistheOilGuy does offer sound advice when he writes at the end of Motor Oil 101, Chapter 4:
"If you are looking for a good oil to use first check your owner’s manual, then make sure you pick the right viscosity grade and do not be afraid to choose something that has better cold temperature performance because that will help with better startup and reduced energy consumption. Learn about the different specifications and applications oils are designed for, then pick a brand that makes you comfortable. "
What benefit do you claim synthetic oil would have given me over my 55 years of driving with nothing but conventional motor oils with absolutely never an engine issue? The only thing I ever did was change the oil and filter at appropriate intervals. And nearly all were driven well into the six figures before selling them aside from my previous TJ that was stolen ten years ago with approx 198k miles on it.
Not to mention the old ads from Volvo and Mercedes showing their engines making it to over one million miles... in the days before synthetic oils were readily available on the store shelves.
To read the opinions of some synthetic oil enthusiasts our engines don't stand a chance of making it to 50-100k miles without using a synthetic oil. :risas3:
I prefer 1 qt cannabis extract oil with the balance being regular old Wallyworld dino. Hundreds of thousands of miles and not one of my engines has ever been stressed out or developed cancer. Frankly they have been the easiest going vehicles to maintain you can imagine. It's expensive but is a superior procedure in every regard.I prefer bacon grease, but you gotta keep it warm (lest it hardens).
Several years ago I went from 3K miles on conventional to 5k miles on synthetic (Mobil 1). Bought my TJ last summer and did the same thing. I now have a RMS leak. I'm going back to conventional next time in the TJ in hopes it slows the leak at least.
Mileage is only one factor on a RMS. Your TJ is also almost 15 years old. Its a rubber seal. It will break down regardless of mileage.My TJ has less than 55K on the odometer and it appears the RMS might have been replaced already. Looks like a pretty new oil pan gasket on there.
My previous TJ's RMS gave up the ghost and started leaking when it had only 50-60k miles on it. Maybe even less than that.Mileage is only one factor on a RMS. Your TJ is also almost 15 years old. Its a rubber seal. It will break down regardless of mileage.
Collapsed oil filters are usually caused by an engine problem, not a faulty oil filter. It can happen with any brand since, again, it's usually caused by an engine problem... not the oil filter itself.Some things I have seen in my few years on this planet..
- Two collapsed orange body Fram filters (A 2.5L and 4L)
Funny how different engines react . Mine had a RMS leak when I bought it and I use Mobile 1 high mileage and the leak has almost stopped.Several years ago I went from 3K miles on conventional to 5k miles on synthetic (Mobil 1). Bought my TJ last summer and did the same thing. I now have a RMS leak. I'm going back to conventional next time in the TJ in hopes it slows the leak at least.
Every 3K miles is excessive for most driving situations. Jiffy Lube and the quick change shops started the whole 3k oil change interval thing... it was just another way for them to convince people they needed to change their oil more so they could make more $$$. For most of us a 5K mile oil and filter change interval is more than often enough.Probably just fine to go back to 3K mile oil changes with conventional.
You are probably right but I do change it myself so the $$ is not too bad.
What benefit do you claim synthetic oil would have given me over my 55 years of driving with nothing but conventional motor oils with absolutely never an engine issue? The only thing I ever did was change the oil and filter at appropriate intervals. And nearly all were driven well into the six figures before selling them . . . . . .
