Jeep throws plenty of heat but gauge wont go to usual mark. I did replace the radiator (non oem) ,it is full should i worry or not
X2, are you certain you installed the correct thermostat which is a non-failsafe with a 195 degree rating? Failsafe thermostats commonly fail in the open position causing the engine to run too cool in temperate or colder conditions, so will a 165 or 180 degree thermostat.What does the gauge read? Did you replace the thermostat with a 195 degree one when you did the radiator?
No, 195 degrees is correct.Didn't replace thermostat and 185 is the correct one i thought
