Teraflex Sway Bar Links
I just got and installed these from TeraFlex. 10" Front Sway Bar Quick Disconnect Kit (3-6" Lift)
SKU: 1743090. Ended up taking the sway bar out, easier to get top bolt out and grind shim sleeve out w/Dremel.
Problem is I already bought the links. I just need the quick disconnects. I think I found some that will work.
Reactions: TokenJo
