The unfortunate JKU & JLU of the day thread
This was taken in Baghdad, Iraq:
83981
Reactions: Steel City 06
@chris apparently you don't NEED 4 doors to be an idot... This 2 door owner tried to fly a 5klbs jeep with a stock dana 30, known the world over for bending without air time.
There must have been a time
when we could have said no.
Here’s the post I stole it from.
The poster says that the axle is sleeved and gusseted. There are more pictures linked there
Check out the “fix” they did to drive it away
I was just taking a second look at this picture. I don't think it's a JK, the ctans crossmember doesn't look right and the front axle looks odd, what are those bolt holes around the pinion? (unless it's the drive shaft flange and I'm just not seeing it.) but I don't think the jk trans crossmember runs under the frame like that.
Edit: looked again, I think it's a unifloppy of some sort.
Should have been fine with the Dana 30 because he has a hi-lift on the hood so it's super offroady and stuff.
Reactions: TJ Hunnicutt
