Thinking about a MIG welder
Chris
Administrator
Staff Member
Sep 28, 2015
35,362
Salem, Oregon
One of the primary uses for TIG is welding Stainless piping for process piping (chemical process, food process and power piping) did a lot of that years ago at Maxwell House coffee. It's also popular for aluminum fabrication such as Marine applications. For food process the piping is capped on the ends and purged with Argon to prevent any interior weld contamination. One of the attributes of TIG is that it uses no fluxes of any kind hence the weld are very clean..
I believe that the majority of my GenRight parts are TIG welded as they are aluminum. I could be wrong. But the welds look like the most beautiful stack of dimes you’ll ever see.
TJ4Jim
1,263
Brookings, Oregon
I had a T-top fabricated for my boat a few years back and they used an aluminum spool gun, the welds were beautiful. That process involves a ton of practice and experience. The biggest problem I have is the ability to see the puddle as I'm welding, getting hard even with glasses.
PCO6
688
Newmarket, Ontario
... The biggest problem I have is the ability to see the puddle as I'm welding, getting hard even with glasses.
I've been welding since my teens and a few years ago I thought I was getting worse not better. Cheap reading glasses solved the problem.
You're never too old to learn new tricks btw. A couple of days ago I learned how to spot weld aluminum. I have to find some new projects!
tworley
1,844
Morrison, CO
All this talk about welding makes me want to buy one. I used to weld in high school and wasnt to bad. Not the prettiest but they held. Maybe I'll take a look and see what it would take to throw in a 220 into my garage....
cliffish
2,453
St James, NY, United States
I am not sure I have room in the box to add another 220 line, already one each for dryer, pool pump, pool heat pump, central ac and a hot tub! Gee can imagine why my electric bill goes to over $1100/month in the summer???
Chris
Administrator
Staff Member
Sep 28, 2015
35,362
Salem, Oregon
spool guns are used when using your mig welder for aluminum.
Got it! That's what I've been reading after posting that, but thanks for clarifying.
So a TIG welder isn't used for thick, hard steel, right? My understanding is that a TIG welder is used for alloys, but can also be used for thinner steels (i.e. stainless steel)?
Flib
378
Nova Scotia
you can weld anything with a tig that you can do with a mig (to an extent obviously), however your technique would certainly be different. Not too many people would ever try to weld half inch plate with a tig, but you could.
TIG is more of a finesse method, typically used on thin metals, aluminum, stainless etc. and is much much slower then mig welding.
In the end it is all the same thing, the melting of parent metals together to form a bond.
Reactions: PCO6 and Chris
Chris
Administrator
Staff Member
Sep 28, 2015
35,362
Salem, Oregon
Great explanation. That definitely put it in perspective for me.
PCO6
688
Newmarket, Ontario
That's true. Similarly you can weld pretty much anything with an O/A torch. It's not always the best thing to use … but you can. I watched my Dad braze the dynamic jaw of a broken bench vice back together in the early '70s. My brothers and I couldn't believe it and one of them is still using it! MIG is preferred for body work but I still use a torch for many things, hammer welding sheet metal for example.
softballnrd27
I've had my Hobart Handler 210MVP for about 3 years now and it does everything I can ask of it on my Jeep. I don't even use the 110v plug. For now, I just use the 30 AMP Dryer plug for mine. I might try and get an electrician to install a true 50 AMP plug in the garage but since I rent that might not be possible.
xackley
In pressure vessels, like generating plants, TIG is used to root the pipes and tubes. Usually stick to fill and cap. MIG or stick for structural.
For home use I find a flux core wire works fine if it is possible to get the surfaces clean. Even if you can't get it clean, it is better than nothing when fixing a crack in your niece's wood stove using the power from a normal wall outlet.
Akitadog
31
Lodi, Ca
I purchased a Millermatic 175 , 120-230v w/ 20/80 gas years ago and it has done everything I've asked to do. Even some 1/2" plate after heating it up with an acetylene torch. I plug it into the driers outlet via 20' 10/3 extension cord that will allow it to reach out to the driveway. It can run a spool gun to for aluminum. I would think you could pick up used one for around 400? You do need a cart for it also.
Flib
378
Nova Scotia
I built bicycle frames for a few years and loved brazing, loved the look of it :)
however brazing is not a form of welding as the parent metals are not fused but still a very strong joint, the benefit of brazing is you can join dissimilar metals.
Reactions: PCO6
mrblaine
TJ Expert
3,939
Quail Valley, CA
With MIG it is very important to have clean, shiny metal. Any rust, paint, dirt will result in a bad weld. Argon or CO gas is easier and prettier that flux core. 120v flux core is good for convenience. But I think the extra smoke and smaller puddle might make it harder to learn.
mrblaine
TJ Expert
3,939
Quail Valley, CA
They are Tig welded, (the aluminum parts) and the giant problem with "stack of dimes" as a criteria for a good looking weld is folks try to mimic the look with steel Mig welds and they shouldn't. Each weld type will have a proper appearance based on the process and material.
mrblaine
TJ Expert
3,939
Quail Valley, CA
The manufacturers have come a long way towards improving aluminum welding processes get them away from Tig for production. Typically takes a lot of horsepower but they are out there. The best I've seen are the push pull systems with pulse welding. I watched a "how its made" type show on making fuel tanks for big rigs and they were using what I believe is that type of welder. The Fab Shop for Savvy's gas tank skids bought one to avoid having to carry them next door to get Tig welded.
Reactions: TJ4Jim
mrblaine
TJ Expert
3,939
Quail Valley, CA
Be happy that all those aren't 110. That would just about double your bill.
