If you believe all that from just swapping to the MSD coil pack and E3 spark plugs I have a bridge for sale in Brooklyn for you. First, the Mopar coil pack already puts out way more voltage than is required so putting out even more voltage, if the MSD even does that, isn't going to help. Older ignition systems could be boosted for often dramatic improvements but modern ignition systems cannot because they had to be significantly improved so they could pass increasing EPA smog test requirements. I actually built higher performance ignition systems back in the 60's and 70's and they helped significantly, they really did, but they don't help in modern engines. Really. The same thing for E3 spark plugs, they don't produce any more power than any other good quality spark plug does, despite their advertisement's wild claims. The only way either would produce more power is if either the OEM ignition system was defective or if the spark plugs were worn out. Really.
But you can believe whatever you want, it's a free country.
