Thoughts on Rancho track bar?
allegedcaveman
California
I recently ordered the ProComp 2"/Rancho shocks lift components. I can get the Rancho front adjustable trackbar for 2-5" lift height for a reasonable price (and additional 10% back through my card). It doesn't seem to have the same clearance curves as the JKS, does anyone have experience with it on a similar size lift? Thanks!
I've had that lift for multiple years, no front track bar needed,but if you insist I think that one will be too long IMHO
Thanks for the replies, y'all. Doesn't take much convincing for me to spend LESS money, so I'll just hold off and try things with the OE trackbar.
Good choice, then if you notice or can't live with the minor offset replace the track bar, but make sure you give everything a few hundred miles to settle first making your decision.
I was on a skyjacker 2.5 with the stock trackbar, wheeled a few times and the ball/socket end finally came uncorked. I was on 31s and open diff at the time, replaced it with a superlift heim trackbar. No issues and I put it in probably 7 years ago. Fairly inexpensive.
