Tight hinges
Kenneth G Zinis
Bethlehem, PA
Picked up '04 tailgate hinges, they look like new, and match my paint, but very stiff. I know they were in sealed, indoor storage for many years.
What's the recommended lube? to loosen these up?
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
You might want to drill into the barrel - you will feel when you hit the pin, and then use a good penetrant - it only takes a 3/32 hole to accept most aerosol straws
Kroil has an excellent reputation- but most anything will be a beneficial.
Tahdig_siah
Ohio
drill a small hole in each of the hinges, use Kroil. If you have a Jeep, you need a can of Kroil. Spray liberally. Here's a video:
