Its finally back together. Kind of a struggle for me.
Struggled getting the case halves together. I would get it together and it wouldn't go into 2WD. So, I tore the main shaft apart and made sure everything was installed correctly. Thinking through how everything moves and the different pieces engage, I know its back together correctly, but it still wouldn't disengage in 2WD. After a bit, I realized that the main shaft kinda falls toward the front of the T-case when you assemble it as the manual specifies (the orientation that my pictures are in). When the mainshaft falls toward the front of the case, the mode selection rings wouldn't fully separate, so it was always in 4WD. Okay, that makes sense...so I put the rear of the case on, installed a couple bolts, and worked the mainshaft back to the rear. I had 2WD! Sweet. So I took the rear case back off, ran a bead of sealant, then put it back together. Tried to check function...and it was bound up. I also couldn't find the little hole for the tone ring drive pin. WTF!!!
So, back apart it comes. I had to clean all the sealant off again (I hate RTV) then I walked away for the night. Tonight, I looked at everything again. Figured out that I was fighting the oil pump in the back half of the case. The drive splines are on the mainshaft, which gets installed into the front half of the case. So, when you install the back half, you have to not only get the oil pump centered well enough to go over the mainshaft (it kinda floats around in the bore), you have to get the splines lined up...blind. They do tell you this in the Service manual...but not in a way that stands out. As soon as I had the A-Ha moment, I read the manual and it clicked. The manual tells you to use the mainshaft to line up the oil pump drive ring. What they don't say is to do that FIRST, with the case clocked so the only thing engaging the case half is the mainshaft.
Once I figured that out, it went right together. I hope I didn't fuck up the oil pump...cuz then its Atlas time. The oil pump is non serviceable and you have to replace the whole case half (and its not available from Jeep anymore).
