Trying to remove the transfer case, then the transmission to do a clutch job. Thought about removing the transfer case along with the transmission...but I am working alone and it seemed to be more popular to separate the two first. My TJ is up on my lift and I have two high-lift hydraulic transmission jacks, plus a 2-ton safety stand. After reading all of the members who did the job on jack stands, I thought this would be a piece of cake...wrong! Supposedly, the Jeep had a dealer clutch job some 60,000 miles ago and it appears nothing has been done since. I am the "second owner" (the real second owner bought it, moved it to his farm and didn't use it or put more than about 100 miles on it). I'm 68 now and of short stature...don't have the strength of my youth, but the shop is well-equipped. I was surprised that the clutch began slipping, as it felt great when I first got the Jeep and I have only put 1,200 easy miles on it. I suspect there might be disc contamination, which is why I want to do the job myself in order to see what actually is going on and then fix it.
I appreciate the suggestions I received about disconnecting the O2 sensor connector...they helped. (the two pieces were stubbornly tight even after the locking tab was depressed).
1) Should I give up on trying to separate the tranny/transfer case (the two nuts/studs I have removed so far have come out together and I expect the rest will too--my instinct is to replace them in order to get proper torquing on the nuts)
2) Right now, I am stuck trying to get anything I have on the nut that, facing the front of the transfer case, is at 1 o'clock. It's behind the transfer case torque bracket and would be no problem for a long extension and socket were it not for the casting that protrudes from the AX-5 tranny. I have tried wobble extensions, universal joints, curved distributer wrenches (remember those?), "s" shaped wrenches and ratcheting GearWrenches...if I can get on the nut, the bracket is in the way and I cannot turn any combination of wrenches that I have. I can't get even a short socket on an extension because of the casting. I've just ordered a set of 6-point flex sockets as a last resort. Any suggestions are welcome!!
3) How tight is the spring retainer that holds the shifter rod on (that needs to be depressed and turned)? I can't really get my hands in there too well because of the bracket that is giving me fits. Arthritis doesn't help.
4) Is it really necessary to drain the transfer case/tranny if one is not going to open them up after removal?
As always, I appreciate the collective wisdom here and I am sure that there will be things I haven't thought of yet that could make my life a whole lot easier (selling the Jeep is NOT an option!)
Kim
Kim
