Why go from 4.56 to 5.13? What’s wrong with 4.88?This is your setup now: 3.73, 31s, 75mph. Looking at my spreadsheet, obviously gears 1 and 2 make no sense at 75, but 3 and 4 do because you may have to downshift on occasion.
With 4.56s and the 31s it's not a bad RPM at 75.
Changing the tires to 33s it is still way better than you current setup. From current setup, you will pick up about 25 ft-lbs of torque and about 20 horsepower and the torque will multiply times 4.56 instead of 3.73.
Now most of the experts will not like the 4.56 solution, I do because I want the lower RPM cruising around. Performance will be better at 5.13, but the RPMs are higher. Below is the 5.13 case with 33s:
With your 31s, 5.13 will put you at right about 3000 RPM.
Although, I must protest again: 75 mph? if you really want to do that, put 29s on it with a 2 in lowering kit and you should be OK. 33s and a lift kit won't help....
You are full of it. I've run 31" tires on the 42RLE with 3.73 gears for longer than you've owned your TJ and done just fine. Averaged 16.5 about the last 10 or so years, how 'bout you? Probably can't do the math.I, like the others, can promise you that 31’s and 3.73 will never produce a good driving combo on the highway with the 42RLE trans
Full of it? Kindly, piss off. Every once in a while you do this ridiculous dance where you suggest folks using/recommending lower gears are out of their minds all because you’re so pleased with stock undergeared crap.You are full of it. I've run 31" tires on the 42RLE with 3.73 gears for longer than you've owned your TJ and done just fine. Averaged 16.5 about the last 10 or so years, how 'bout you? Probably can't do the math.
You are full of it. This guy has problems with his Jeep that prevents him from maintaining 75 in overdrive on the freeway which has nothing to do with the final drive ratio. That's all this thread is about sparky.BTW - 2900 at 70 generates about 17 mpg on 33’s in my experience. Would you like to swing by and verify that math for me? Not sure if I calculated it right.
Full of what, real world experience? You’ve got someone trying to push 75 mph in a giant crate on wheels with at best 235 ft lbs of torque (at 3200 rpm) at 2150 rpm which is not where peak torque is, so even less. That is a recipe for anything but good performance.You are full of it. This guy has problems with his Jeep that prevents him from maintaining 75 in overdrive on the freeway which has nothing to do with the final drive ratio. That's all this thread is about sparky.
It runs very well with OD off and as ill advised as it may be I’ve had it up to 80 in third.for your “issue”, it’s hard to determine what your issue might be if anything. I, like the others, can promise you that 31’s and 3.73 will never produce a good driving combo on the highway with the 42RLE trans. Does it drive decently if you turn off overdrive? If it still doesn’t then, maybe you have something to look for.
I don't know what changed for you but running very well in OD off vs running poorly with OD on is pretty indicative of one thing: insufficient gearing.It runs very well with OD off and as ill advised as it may be I’ve had it up to 80 in third.
As @pagrey alluded to, I went from being able to maintain 75 in OD to not being able to in a short period of time. My primary focus right now is finding out why because whatever issue has caused this there’s a pretty good chance it could leave me stranded.
I lost interest reading much of this but did anyone suggest starting with the basics and plugging in a cheap live time scanner and see if it’s pulling spark or if the fuel trims are going full lean/ rich so you can try and rule out ignition or fueling problems? The fact that something changed is the key here as mrblaine said.Well this is certainly one of the more standard answer shitfests I've seen in awhile. I hope this isn't a trend and folks actually start reading and listening to what the actual problem being described is.
It used to work, he didn't change the gearing higher and now it doesn't do what it used to do. Fucking gearing won't fix that. How hard is that to understand? (rhetorical since apparently it is impossible)
Thank you for the heads up.When mine stopped maintaining speed it was the result of two issues:
1. Clogged cats and
2. Torque converter was not fully locking up. Once the torque converter was replaced (and other transmission work), maintaining 70-80mph was easy again.
I had intermittent check engine light and codes leading up to the cats. When the shop replaced the cats, the first thing they asked when I came to pick it up was if the car was sluggish and hard to maintain high speed. It was. He then showed me a completely destroyed and dislodged cat in the pipe he removed. My sluggishness improved as did the high-end speed.Thank you for the heads up.
How were the trans and the cats diagnosed?
