Good Morning,
I recently installed used full doors on my 98 TJ. The passenger door works fine, but the driver-side door needs a new outer handle. The outer handle just flapped around and didn't activate the door mechanism. I installed a new inside handle (which seems to work fine) and an outside handle. However, the outside handle doesn't work; I can only pull the handle open for approximately about an inch and a half. I sprayed PB Blaster on all of the inside door components, and still, there was no luck. Any suggestions?
Very Respectfully,
Paul
Very Respectfully,
Paul
