Preface: This is not a TJ specific antirock. This is a universal kit.
Bar width: 45”
Arm: 18”
Link: 14”
Wheel: Moab 16”
Spacers: Spidertrax 1.25”
I’m having contact issues between the tire and the arm while cycling the suspension. This is when cycling sides separately. I’ll post a picture of the arm at ride height @mrblaine mentioned I need to get the arm higher at ride height to avoid contact on the way up. I took his advice and now have the arm as high as I can make it with 14” links. Any higher, the arm wants to go through the tub at full bump.
The arms cannot afford to have any less bend in them, on the down travel you could fit several playing cards between the upper perch and the arm. No room for less angle.
I pulled my liner and flare to get a better visualization. It’s clear to me that I either need a shorter arm with a longer link or less wheel back spacing.
A fellow jeeper is sending me a 15” TJ specific arm to experiment with. Tomorrow I’m going to stop at the hardware store and pick up a few washers to mimic 1/4” to make the wheel have 3.5” BS. Curious to see if .25” less BS helps. Spidertrax offers a 1.5” spacer so this is an option if it fixes my contact issue.
I hope these photos are clear to see what is happening. Please list any suggestions.
Driver side overall setup:
Passenger side initial contact still able to turn by hand:
Full bump, unable to turn due to tire/anti rock contact:
Bar width: 45”
Arm: 18”
Link: 14”
Wheel: Moab 16”
