About 3 months ago I was leaving from trail riding and pulling out from a gas station, while shifting from 1st to 2nd the Jeep did a stutter almost as if the power was cutting out, I pushed in the clutch and re-engaged and it drives fine after that. This has happened a few times since then, usually going from 1st to 2nd gear, today, however, I was getting up to speed and shifting to 3rd and the Jeep shut off. All the accessories worked so I coasted to the side of the road, tried cranking it over and it would give a full crank, but it would not turn over and start. I noticed the dash light with key and the line through it came on. I removed the key from the ignition, put it back in and it started right up and I finished my drive. I've tried researching this and have seen, bad ignition switch (replaced a year ago), a camshaft position sensor, or a crankshaft position sensor. I hate to replace all 3 if someone has the answer to this.
