I was driving my 1999 TJ (6 cyl/ manual / 180K miles) and after about 30 minutes experienced no power in 5th gear with all other gears OK. Jeep had been running fine up until that point. As it was going to the shop for an odd brake issue, I asked mechanic to take a look. I had searched the forums prior and saw many posts about a clogged catalytic converter. Mechanic noticed the same issue with 5th gear (scanned, no codes), but said a clogged catalytic converter would cause the issue in all gears. He suspected the clutch, which I doubt. Drove it home and no issue, hasn't reoccurred in a few days.
Drove it the next day and the Jeep wanted to stall in lower gears. I put Sea Foam in the tank and changed the air filter (a tune-up was done less than a year ago plugs/wires/distributor.) The problem continued — in the first 5-10 minutes of driving the car wants to stall out both while driving and while warming up. I again searched for solution and noticed cleaning the IAC was recommended and that there could be a problem with the O2 sensors. No check engine light.
I am trying to attack this in the proper order and looking for some guidance based on the symptoms of where to start first — IAM, O2 sensor, clogged cat.. other?
Thanks!
Thanks!
