SOLD TJ Width Rear Dana 44
Dana 44 with 5.13 gears, 35 spline ARB air locker (PN RD147) and carbon off-road 35 spline chromoly axle shafts. Axle is set up for triangulated rear and coilovers. Can be easily converted back to stock with coil buckets and upper mounts/track bar mount. Brand new brakes and rotors. ARB, axle shafts, and gears are brand new. Axle shafts/rotors can be run at 5x4.5 or 5x5.5.
That’s nice but, cant afford gear change, running 4.88
What suspension is the truss designed for? I have a 3 point rear
Do you have means of weighing it , diff alone 140 Pnds? Without truss brakes etc…I will get quotes mounted on a wood pallet. I am just getting an idea on total cost including gear change out material cost. I currently have a disaster Dana 35 i don’t want to fix
Ok, it be a sin to hack off that truss, not sure I can convert to 4 point. Never mind about the weight, it looks bleak picking up your offer, bummer
My buddy says he doesn't want this and I am tired of dealing with it so $1500 to anyone that coordinates the shipping or local pickup (preferred). The 35 spline ARB and the 35 spline shafts are a deal at $1500.
Or I can take it apart and sell the locker and shafts.
RD147 ARB locker -$800 (locker only, no compressor, you would need to have/buy compressor, solenoid, and tubing to run from solenoid to diff connection).
https://store.arbusa.com/air-locker...kZEqJa5plu4AlVtR0_B1vcuxSCMc-dIyA5CsSlz1R_CV8
Carbon 35 spline shafts - $700 includes seal and retainers installed (currently set up 5x5.5 but can be set up as 5x4.5).
https://carbonoffroad.com/carbon-tj-rubicon-rear-Dana 44-35-spline-axle-kit.html
Price is local pickup. Add $50 per item to ship standard USPS slow as possible.
