My Jeep does something weird. Some times when you lift off the gas, it spools down to 1500 rpm EXACTLY and stays there for a second or two before returning to idle speed. When it decides to do this, it does every time you lift off the gas from the moment you start it until the moment you turn it off. If it doesn't do it from the start it does it not at all. Some times it will do it several days in a row then not do it again for a month. Check engine light does not come on ands it's not throwing any error codes. Nothing appears amiss at the throttle body and the peddle is fine. Sitting in the driveway the symptoms are as I've described. When driving it feels like there is excessive lash somewhere in the drivetrain. PITA to diagnose because you don't know when it's going to happen and, of course, it doesn't happen when it would be convenient to work on.
Oh, yeah, 2004, 4.0, 5 Spd.
This seem familiar to anyone?
Philip
Philip
