Ill take one and post it...Looks nice! I’d be interested in seeing a full shot of the jeep, flares/top and all in some nice daylight to get an idea of the finished result
Yes, I really like them.... When I have time, I am going to Raptor Line the interior of the hard top. I hate that off white..lowback seats?
Looks great! I am in the process of picking a color and doing all my silver.. You know this stuff comes in a tintable version...Great info here. I raptor lined my 2011 Jeep JK in 3 phases. If you want to put in a good bit of work, you can save a bunch of money over having it professionally lined and still get amazing results with this stuff. I did the hard top (inside and out - didn’t like the white interior), tub and rails(got tired of the smelly carpets), and today I removed the stock flares, rear bumper and side steps and finished them off. As has been stated several times, your results are fully dependent upon the prep work you put in. You’ve got to plan several hours for prep work on flares and bumper. I spent one full day on the hard top. For the interior tub, I believe I spent 4 days between prep, removal of all interior, removal of sound deadening material, and then application and reinstallation. I scrubbed everything with soap and water, pressure washed the hard top, used a degreaser, sanded everything down. I used 120-180 grit discs on the tub and rails and 80 grit on the other parts. I then wiped everything down with mineral spirits and alcohol. Then I used self etching primer and adhesion promoter (2 coats of each) on tub and rails and plastic primer and adhesion promoter on the other parts. I set my air compressor to 60 psi and let it rip. 2 coats on everything and it has held up very well! Been through car washes and no chipping or flaking. I can’t yet speak for the bumper, flares and side steps, but I don’t expect anything less than what I’ve experienced thus far.
I tried to get you a close up...Looks nice! I’d be interested in seeing a full shot of the jeep, flares/top and all in some nice daylight to get an idea of the finished result
Do it right and don’t shortcut it.Any tips on masking tape and when to remove it?
I removed the flairs. I didn't remove the hard top. I spent hours masking the jeep. Throw away the regular Shutz gun and invest in the adjustable gun. I shot mine at 2.5 turns out on the nozzle. And most important, DISTANCE!! I was like 16-20" from the surface. If you get too close, you get a shiny build up of goo!!! I bought a can of their adhesion promoter for the top and flares. Cant hurt. If you sand the top into the white, spot primer it. 8 hours of prep to spray for 15 minutes.... Its all about the prep.... And don't even think about taking out the hard top side windows. I researched it and its beyond a pain...I did remove the rear window.....Looks amazing. You inspired me to do mine.
How is the texture? Is it smooth enough it won't catch lint off a towel like velcro?
What pressure did you run your spray gun?No it don't catch lint.....
I like the blue. What color did you add?I have my whole body sprayed in Raptorliner and it doesn't collect fibers from a towel at all. In fact I waxed it the last time I washed the Jeep. View attachment 154503
I believe this is a standard color from Raptorliner. The Jeep was sprayed this way then I bought it.I like the blue. What color did you add?
I ran 60 PSI, removed tape 20 minutes after last spray and 1 hour between coats....What pressure did you run your spray gun?
How long did you wait before removing the masking tape? How about between coats?
NICE!!! Get us a full side shot!!I have my whole body sprayed in Raptorliner and it doesn't collect fibers from a towel at all. In fact I waxed it the last time I washed the Jeep. View attachment 154503
Curious....Did you notice a difference in the sound after you did the hard top?
