TJ Fest 2021
Took my TJ off-road. Sometimes transmission sounds like it's chewing rocks
Franco
Austin, TX
Today I took my 4-cylinder, 5-speed TJ to an off-road trail in Colorado. Everything was going well for a while, and then it happened. Going downhill in first gear there came this ugly noise from underneath, as if the gearbox were chewing rocks. Then I came to a complete stop and the noise persisted for a few more seconds and then went away. That happened several times. When I got back on the pavement, no problems. Based on my description, do y’all have any inkling what the problem could be? This happened in 2H, 4H, and 4L. Thanks.
F
Franco
Austin, TX
Is it possible your transfer case was not fully engaging?
I’m not sure. The thing that makes me think the problem is in the gearbox is that a couple of times, after the rattling started, I came to a full stop with the clutch pressed and the rattling continued for several seconds. When you are stopped, nothing is moving in the transfer case, I don’t think.
