Local muffler shop that's into big fabrication jobs, like rock crawlers. Cost $75.Mind if I asked who was able to fabricate these for you? Around here metal fabrication is hard to come by, as I live in western NC
Sent from my iPad using Tapatalk
Got any drawings or specs that could be used?Local muffler shop that's into big fabrication jobs, like rock crawlers. Cost $75.
Please tell us those shackle tabs are through-welded front and rear and not just surface welded as I suspect. Surface welded shackle tabs are not up to vehicle recovery use.
Those look pretty light. Shackletabs are built to "support" only the 25% of the trailer weight so if those are for a 3500# axle they were designed for about 1000# each. Not what I would want to hook an 8000# winch too.View attachment 38119 View attachment 38120 I used trailer spring mounts either bolted or welded to bumper (I've done both). Grade 8 bolts & 1/4" backer plate behind bumper. Cheap & secure!
The tow bar mount is fine, there's not much load that is placed on the Jeep by a tow bar as it is all rolling weight which isn't much. The eye bolt is interesting if it is rated strong enough, can't say that I've ever seen an eyebolt ever used on a Jeep for recovery. Sufficient strength is of course always a key requirement for a recovery attach point. Adequate recovery hooks/attach points are typically rated at nothing less than around 9,000 lbs, the last set I installed were rated to something like 10,500 lbs.View attachment 38137
Jerry, eye bolt for recovery, shackle for tow bar mount. Welcome your comments.
