TPS Pigtail Wiring
Jeeps4me
Forest, VA
I am new to the forum so forgive me if I repeat something that has already been posted. I took the advice of other members and ordered a Mopar TPS from Quadratec to replace the faulty one on our ‘03 TJ. When I removed the pigtail that was connected to the TPS sensor, the off white pigtail housing broke. I went to AutoZone and picked up a Duralast pigtail connector #1186 for just over $40. When I opened the box there was a Mopar pigtail inside...cut the factory pigtail off, connected the 3 wires, and was back in business. Hope this helps someone.
Dude! You just saved me hours of searching! This looks like exactly what I need! Broke a wire being too rough while moving the harness back for a head gasket job about seven years ago. TPS has been bucking me around back and forth every year since. On and off and always before inspection. Can't seem to repair it, permanently.
I hope this fits. Looks identical to the female tps harness adapter for my 98 TJ. Just without the yellow clip that goes inside it. Same 'blades' as they're called, apparently. And even the silicone gaskets to fit in. Comes with two gauge options. I assume the higher gauge is for my 2.5.
THANK YOU!
-MARK
