Tracing an oil drip on a newly purchased LJ. Hoping its not the RMS, and based on reading about others’ experiences, seems like the valve cover is the place to start looking.
Looking under the hood, seems like there is quite the build up around the valve cover. A couple of questions:
- the rear PCV seems quite loose, and is quite dirty around it. It moves/wiggles without applying any force. Seems like this could be one of the sources. Should this be tighter/new grommet needed?
- should there be a nut holding this down (rear on driver side) - pictures attached
Thanks all!
Thanks all!
