aswetich New Member Joined Mar 20, 2024 Messages 4 Location Gaylord, Michigan May 8, 2024 #1 My transmission cooling lines are flopping around because the plastic retainers that slip on the oil pan bolt studs are shot. What off the shelf stuff can I use to retain the lines?
LONGJP2 TJ Expert Joined Aug 11, 2019 Messages 4,944 Location S. Illinois May 8, 2024 #2 I found a random line holder bracket at a Pick n Pull that I bolted to an unused boss on the engine. I'll try to get a picture later. Maybe you could make something out of one of these.
