I have a automatic 06 tj with 143000 miles. In the last couple months it has developed a few problems. It has the codes po740, po700, po508. When it first threw the codes i took it to a trans shop. The guy there said that the torque converter wasnt locking up all the way at hwy speeds. $2500 for new torque converter and trans rebuild(he recommended a rebuild just because of the mileage on the jeep). I was planning on replacing the TC myself and not worrying about the trans. But just in the last couple days it has had these problems-
Sometimes not shifting into 1st(staying in 2nd gear) when i slow down for a turn.
When I shift to drive it will sometimes start out in 2nd.
After these problems I started wondering if the TC was the problem as I've heard a something about checking the clutch solenoid valve?
Has anybody had these problems/codes? I figured I'd post these questions on here because of all your wisdom! thanks
