Support the tc skid with a jack in the middle of the skid and slide them out after youve taken the bolts out. Thats what i did. Make sure to dab those bolts in antiseize!So getting rid of my 4 inch rough country lift. Down grading to 2 inch jks. So what is the best way to remove the transfer case drop spacer? I have a set of original bolts.
He means that when you remove the TCase drop the engine will be tilted down and so the fan blade could contact the shroud. Just make sure the fan blade turns freely. Otherwise you’ll overheat pretty quickly.It's a cheap rough country lift I am removing. PO just did the bare minimum. So don't think fan shroud will be a problem.
Where do you have Allen head bolts? That’s oddThanks will keep an eye on it. Soaking the Allen head bolts in kroil hopefully they don't break.
75-80% of torque spec. 42ft/lbs will do with anti-Seize.Use substantially less torque than 55 ft lb if you decide to slather anti seize.
Also, whoever told you to support the TCase skid and remove the bolts told you wrong. You support the transmission at the bell housing, remove the 4 bolts at the transmission mount in the middle of the skid. Then remove the three bolts on one side of the TCase skid, remove the drop, and hand thread the stock bolts back on. Then do the same on the other side. Antiseize the bolts is a good idea.I bought an endoscope online and an extra long spray straw. Going to spray the drop threads today and the body mount bolts. The endoscope is ok, at least I can see where to spray.
