Dylpickle200
Agreed. I am having good results from adding density to the skid plate. But the harmonic vibration is still present above 50. I think I will need to add weight directly to the TC housing to eliminate the HV. Any ideas?
Did you ever solve this issue I’ve been having a harmonic vibration in mine as well 05, 42rle, Tom woods front Adam’s rear shaft, Advanced adapters sye, hp 30 front 44 rear regeared to 5.13 and ox lockers on both ends. Pinion angles are perfect and I’ve tried variations from +2 to -2. Changed wheels and tires. All to still have the pulsing vibes above 60ish. Curious if adding weights to your TCase made any improvement?
