Transfer case shifter question
drdfblackm
Flagstaff AZ
I have a very simple question. Can you post a photo of the transfer case shifter installed with the spring? I am just wanting to know if it wraps around the front or behind the shifter itself. I have a DV8 transfer case shifter that was given to me as a gift and well I didn't pay as much attention to the orientation of the spring as I should have. If anyone has installed one of these did you have trouble getting the spring installed?
Thank you for your help
Is this what you're looking for?
I figured it out and could not figure out how to delete this thread....however I appreciate the help.
There was a small set screw that I wasn't even seeing that helped remove the handle.
Now my dumbass has the lever installed wrong on the transfer case itself with the new Savvy cable....so I have to flip that around....shift pattern is wrong on the transfer case.
Reactions: macleanflood
