Well my 03 TJ cooler lines bit the dust yesterday now its stuck in the driveway, starts up but when you shift to any gear the shifter just slides back and forth will not engage any gear. I realize its most likely empty is this why the shifter is doing that? Not sure if I should fill up with fluid to see if it engages or if the transmission is toast. Any ideas? I know if I fill it up I hate to see $80-90 in fluid just leak out.
Question 2 when replacing those lines does the exhaust need to be removed? I found a company called www.linestogo.com and debating to buy there system or pay the extra and get a set of OEM lines from Mopar.
Need help!! Thanks
Need help!! Thanks
