I didn’t think of that. I put my transfer linkage on and drove like 10 or so miles stoped put it in park then like a min later put in drive moved forward a few feet then back in park. Went to back up then n it wouldn’t move.
It's related to the transfer linkage install, probably not adjusted correctly.
You will need to get under as Jerry mentioned and make sure your actual transfer case position lines up with your lever. If you installed an aftermarket like Savy cable shifter linkage, the instructions should tell you how to verify you adjusted it correctly.
