What are risks of waiting 500 miles to fix? Anything we should be worried about?
I’m guessing I need a new line and constant tension clamp to fix (hopefully after our vacation)
04 LJ Automatic transmission 88k miles
This is it, trim, reclamp, roll- not a major problem, and you have lots of hose it appears.I'd snip the very end off that hose and reinstall it with a worm drive clamp. A worm drive clamp is not the preferred type but it'll do. A constant tension clamp is better but harder to find.
Clamp the hose closed with long-nose vise grip or similar and have someone stick a finger on the radiator port until you can get the hose back onto it. You won't loose that much coolant.
Nice. I’ll do that in morning. Thanks for all the help everyone!This is it, trim, reclamp, roll- not a major problem, and you have lots of hose it appears.
I believe Jerry means trans fluid, not coolant on the port part. It is a trans cooler line FYI that holds trans fluid. I cant recall if the line is 5/16 ID or 3/8...argg... Either way a worm drive will be adjustable and will hold it just fine until you change to the other type if you desire. I personally dont care of the tension type but I guess considering 90% of the clamps you find these days are Imported junk and not worth buying. Typically Napa seems to carry good ones. Enjoy the tripI'd snip the very end off that hose and reinstall it with a worm drive clamp. A worm drive clamp is not the preferred type but it'll do. A constant tension clamp is better but harder to find.
