Hello there! I have an 06 TJ Rubicon with around 117000 miles. Had her for 8 months give or take, I drive it daily.
About 3 months ago, I started having problems going from first to second gear, where if the RPMs were too high it would kick out of the second gear when I eased off of the clutch. I have since changed the way that I engage second and gently baby the shifter so it doesn't kick out.
The problem hasn't gotten any worse since it became a thing. I thought about repairing it, and then learned that for the time money I would probably have to just get a reman which I have sources for. I can't go down that road for a while though, does anyone here know much about this transmission and what the potential issue could be with second gear? I had thought that it might be a problem with a synchro going bad, but I'm not even positive if there is one between first and second gear. Thank you.
