Thank you. As a show car that is also fast it is no longer being used as a Jeep, so to speak. Red line is 5,500 rpm and 5,000 is the optimal shift point in head to head competition. The entire engine has been blueprinted, balanced and is optimized for performance within inherent limitations. The frame, suspension and all underneath look new or freshly painted.
The interior is immaculate and it has a substantial Kicker sound system. With 4.88 gears the 5th gear overdrive puts 70 mph at 2700 rpm. It is totally stable and easy to drive at 90 mph with the sport tuned suspension. I'm not trying to make it a dragstrip vehicle but every show car should also have some go. It does. Golen gives it a 3 year unlimited mileage warranty with the rev limiter set at 5,500 rpm. When it's not going to a car show or cruising on a beautiful day it is in the garage under a car cover. In the 15 years I've owned it I have done my share of mudding and rock climbing but it's 21 years old and I'm 67.
Purpose has changed, but the next owner will be getting a 'new' 1999 Sahara with lots of power they can modify to suit their own purposes. I hope the purists on here understand I'm not ruining it, merely tweaking it to suit my current preferences. Back to the original question, does anyone know where I could find a light weight flywheel if I go that route?
One more important point. The factory setup had 225 lbs. of torque, it now has 325 with the 22 lb flywheel. (see above dyno results) Would a 15 lb flywheel really cost me that much pull?
