I've thought about getting a tubing bender before and always talked myself out of if due to the cost of the bender PLUS the dies. And then I am worried about the learning curve that would come with it and how much tubing I would end up wasting before I got my bends correct.
My problem is the closest shop to me is over an hour away so I can't just pop over to get something bent up for me. But then I look at the cost of pre-bent items and almost talk myself back into buying a bender.
To do my front axle correct I am going to need a bent trackbar to clear my front diff cover.
Right now I have a Poison Spyder sport cage which is a mix between the stock B pillar and then add-ons.
I'd like to build a seat frame that tied into the roll cage.
But once all this work is done I'd have a tool I'd hardly ever use again.
Buying a pre-cut cage from say GenRight is $1,800-2,000.
Bent trackbar from GenRight or TNT is $600+
No one that I know of make a base for TJ seats that ties into the cage.
What do the rest of you do when it comes to stuff like this?
