Edit- Excuse the yapping
Edit#2- Very long story short,It was a lot worse than I thought,Kinda expected but still bad.
Uhm....Hehee
....no (Im giggling as i'm typing this lol) basically everything apart from the trutrac&bearings
At 1st I thought it was the the trutrac (i've blown one up,before,gears still spinning as such,just it making noise etc) Long story short, to sell that that Dana 44 I took it apart and found that I ended up breaking a chromoly shaft, several of the ring gear teeth were cracked along the whole way, some of them having multiple cracks on a single tooth. So I then replaced all the bad parts in it and sold It
After 4 Dana 44 rears within the span of months I wont be using them no more as they simply don't hold up to my shenanigans.
So after consideration im just gonna go with a full floater 35 Spline ford 9", I already have a Currie 3rd member and housing (which im not gonna use, since i'm now going with a fabricated 9" housing to match the width of the front HP44 I have from an old ford) and im doing coilovers in the back and a homemade "double triangulated" midarm setup that i've yet to build out and for the front im just gonna do a 3 link, Most likely doing savvy brackets though (I already have their truss just need the frame side stuff)
