Yeah coil pack is fine but I wanted some kind of confirmation that maybe the spark plugs/coil pack could hypothetically cause the PCM to not signal the 5 and 6 injectors. So, definitely good info to have but new coil pack didn't change anything. I took the spark plugs out again and cleaned them and the ports. Made sure they were threaded and torqued.I didn't mean to suggest that he had a bad coil pack, only that the PCM can shut down injectors for a couple of reasons. I think his coil pack is good, otherwise bank 1 would also be affected. Simplest explanation here is that the coil boot for #5 and/or #6 is not seated on the spark plug.
